PLEASE HELP,!!!!!
Old Mar 26, 2019 | 04:01 PM
W221s600's Avatar
2008 w221 s600 v12 biturbo
PLEASE HELP,!!!!!
I DRIVE A 2008 W221 S600, I RECENTLY HAD A MISHAP WHERE THE CAR LEAKED COOLANT DUE TO A RADIATOR HOSE THAT POPPED OUT.. I WAS FORCED TO DRIVE IT HOME CAUSE IT HAPPENED IN THE MIDDLE OF NOWHERE. DUE TO RUNNING THE CAR WITHOUT COOLANT I ENCOUNTERED A FEW PROBLEMS, AFTER FIXING THE HOSE THE CAR IS IDLING HIGH, ENGINE MISFIRE AND SOUNDS LIKE IT HAS A VACUUM LEAK, ALSO ABS, EBV AND ESP LIGHT IS ON. I PUT IT ON THE SCANNER (OBII) SAYS IDLE CONTROL VALVE FAULTY AND CODE PO300.. CAN ANYONE PLEASE TELL ME WHERE THE IDLE CONTROL VALVE OR IDLE CONTROL SENSOR IS LOCATED,?
Old Mar 27, 2019 | 08:29 PM
The Thomas J's Avatar
2010 MB S550, 2017 MB SLC 300
I predict that this isn't going to end well.
Old Mar 28, 2019 | 06:59 AM
W221s600's Avatar
I managed to find the vacuum leak, it was the brake booster vacuum house that broke from the intake manifold, ordered a new house hopefully this will be the solution to my problems...
Old Mar 31, 2019 | 01:20 AM
That's great news. I am happy it worked out for you.
Old Mar 31, 2019 | 04:23 PM
Bklyn's Avatar
S550
I am happy this worked out as well.
