need help with battery issue
Old May 11, 2019 | 06:29 PM
xxfightclubxx's Avatar
s550
Ok so here is the issue. Lets say I drive my car and get home and use the key fob to lock the car. after the car sits for about 1 hour. If i come back out to use the key fob to unlock the car. the car is completely dead. it wont unlock the car. i have to manually use the key to unlock my car. but i notice as well when i open the doors the lights dont come on. once i stick key in the ignition the car will turn on and start and act normal. it just notice my clock is turning like its reset or something. I have put the front and rear trunk battery on trickle charges to make sure the batteries are not dead. they seem fine. So what is the issue? I cant figure it out. Is there another battery in the dash or something that im not able to get too? thank you in advance.
Old May 12, 2019 | 07:46 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
It seems as if the main battery voltage is going low. Usually this batteries are good for about 3 to 4 years. Not sure what year your car is, but the main battery is going to be in the trunk area or in the front.
Old Sep 11, 2021 | 04:57 PM
m6dede's Avatar
w221 s600
Hello mate,
I am having the same issues as your described after I replaced my two batteries. Did you solve yours in the end and how? Would appreciate some help.Thanks
