2009 S550 with ABS & ESP error code
Old May 19, 2019 | 02:19 AM
finally_home007's Avatar
2009 S550
i went to start my car this morning and recieved an error message that ive never seen before.Its causing the steering wheel to become like theres no power steering and the brakes are hard as if theres no power braking. Ive seen that several owners have experienced the same error messages and ive located a video on how to access the "hidden" menu by pressing 2 buttons on the steering wheel but i cant manage to access it myself. Is there anyone that can assiste me with this/?? i really need help. thank you in advance!
Old May 19, 2019 | 04:03 AM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
You need to perform a scan of the vehicle. Hidden menu will not give you any diagnostic codes.
Old May 19, 2019 | 01:31 PM
2009 S550
ok so i need to take it to a shop?? i was askng about the hidden menu becauuse it appears that this guy had the exact same issue as me and that cleared up his problem... so you recommend just going to a shop/>?
Old May 19, 2019 | 03:23 PM
DaleB's Avatar
Veteran: Army
2007 S600
Welcome to my world.
From what I have read, this could be something as simple (and relatively cheap) as a wheel speed or steering angle sensor. It could also be a bad ABS/ESP control unit. You won't know until the car gets some diagnostic attention. I suppose it's not unheard of for this to be a one-time random occurrence that will go away on its own and not come back... but I'd put about as much faith in a lottery ticket. I could be completely wrong and just judging based on my own experience and what I've read here and on other M-B forums.
In my case (and maybe yours as well) I don't think it's a speed or angle sensor, because it happens before the car even moves. If you know how to use an OBD scanner to find and troubleshoot diagnostic codes, they're relatively inexpensive to buy. There's a learning curve, if you don't already know how these things work.
Old May 20, 2019 | 09:58 AM
2009 S550
Thank you very much.. im getting my car towed to a trusted shop this morning that has serviced the car for years and gonna have him take a look at it.. keep ya fingers crossed for me please!!! the wheel sensors were loose in 2 of the wheels and i had them removed about a month ago... nOW alll of a suddden im having these issues, could that be the issue?? but if so why the problem just now??
