ESP - ABS - Cruise Control
Old Jul 18, 2019 | 03:27 AM
ahmed.elshazly's Avatar
W221 S550 2007
Exclamation ESP - ABS - Cruise Control
Hi All,
I have the ESP ABS errors on the cluster. In addition, I have the Cruise Control not functioning. After checking the front right wheel sensor I found it broken. Will it solve all the errors in case I replaced the sensor? I am just inquiring because the wheel sensor is somehow expensive in my location
Thanks in advance
Old Jul 18, 2019 | 09:54 AM
DaleB's Avatar
Veteran: Army
2007 S600
If the wheel sensor is bad it will absolutely cause the symptoms you have. It may or may not be the ONLY problem, but you're definitely going to have to replace it. I found them from several sources for around $50-$60 US for a good German aftermarket part, or about double that for the M-B part. You just need to find a vendor who will ship to Oman, some places may not do much international shipping.
