Is there a 2nd seat control computer?
thanks!
Edit, is this it? https://parts.mbofwilmington.com/oem...ule-2218707493 . Anyone know what this module controls?
In fact it was 2 issues
1. Lumbar not holding setting - mine actually had the problem of the actual set-point changing (and not so much loosing pressure due to solenoid/bladder/piping leak(s)). I ended up keeping a "log" of the two lumbar settings, to prove it was changing by itself - helped get extended warranty claim approved. Changing the controller fixed this problem. So maybe check if its the setpoint setting that's dropping to zero/other, or the actual pressure reading - these are shown as two different representations on the screen
2. All bladders dropping pressure - again under warranty the complete bladder/solenoid/piping assemblies (cushion and backrest) were changed, which fixed the problem
Finally a trick I found was that if you use the "easy" exit function (ie pushes seat back when getting out), when it goes back to "memory" position ready for driving it re-pressurises bladders to their set-points)
Hope it helps
