I have an S550 2008 4Matic. I was driving the car normally then parked in a shopping mall car park, left the car for about 20 min, when I came back to the car the engine is switching on idle but the gas pedal is not working. I left the car there the whole night. When I came again this morning it worked fine. I drove for around 15 minutes to reach home switched off the engine then on again the gas pedal is not working like yesterday.
Can anyone help what to do to at least drive it to the nearest workshop?
Best to pull codes using MB diagnostics. Steadfast on DIY without codes, could be pedal sensor check connection if fine replace pedal assembly with used part: https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
