Distronic Not working after Grille Replacement?
Old Aug 21, 2019 | 02:07 PM
sdppm's Avatar
s550
Question Distronic Not working after Grille Replacement?
2013 S550. Replace Grill with aftermarket Grille. Distronic is giving me errors on the mirrors and the adaptive cruise control doesn't work. I don't know if it is just a coincidence or if the new grille is causing the problem. I cleaned all the sensors as called for in the manual.
Old Aug 21, 2019 | 05:39 PM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
Probably just a coincidence, the plate on the grill is just protective.
Old Aug 21, 2019 | 06:36 PM
sdppm's Avatar
s550
Found Problem
I removed the aftermarket grille and drove the car, the distronic work as it should. I put the old grille back on and it still worked. I reinstalled the aftermarket grille and it didn't work. I guess it is not sending the radar or whatever through the new grille. they look the same but it doesn't work with the new grille.
Old Aug 22, 2019 | 03:46 AM
07CL550Benz's Avatar
2007 CL550
Yes you're correct. I believe there's elements in the paint that block the sensor.
