Help with my 2007 S550
Old Sep 10, 2019 | 12:42 PM
NikitaZ's Avatar
2007 Mercedes Benz S550
So I recently bought a 2007 S550 that had a slight shake in idle it the computer said that it was a multiple cylinder misfire which I thought easy fix and the 02 sensors for both banks were out but it drove fine and I drove it for 1 day, the next day I drive it on a 2 min drive park it leave and after 2 hrs come back start it it starts up then stalls 4 seconds later I try that couple of times with the same result then it completely stops starting or even turning over no sound what so ever press to start no sounds at all just dash goes into on mode with esps light on and I believe srs light the rear battery was bad it was leaking just bought a new one but before I tried a used one and it still did the same thing any ideas what it could be I check the fuses relays everything is good theit
Old Sep 10, 2019 | 05:03 PM
DRTYLNDY's Avatar
Which battery did you replace? The engine bay battery or the one in the trunk?
Old Sep 10, 2019 | 06:09 PM
NikitaZ's Avatar
I replaced the rear one and it still doesnt start when I press start everything lights up but no click nothing and I check the starter battery it's all good
Old Sep 10, 2019 | 06:16 PM
NikitaZ's Avatar
It also has these 4 codes
P064D Internal control module bank sensor 1
P2237 02 sensor positive current control circuit/ open bank sensor 1
P2240 02 sensor positive current control circuit/ open bank sensor 2
P0444 Evaporitve emission system purge control valve circuit open
