Backup Camera Fail
Old Sep 20, 2019 | 01:55 AM
bigkev21's Avatar
2010 S550 4-Matic
Backup Camera Fail
My backup camera is glitching and goes black from time to time. Dealer wants $1,500 for a new one. What are my other options?
Old Sep 20, 2019 | 05:07 AM
07CL550Benz's Avatar
2007 CL550
PM me, I've got a camera I could sell you for much cheaper. I can't guarantee your problem is in the camera itself but let me know.
Old Sep 20, 2019 | 06:35 AM
bigkev21's Avatar
2010 S550 4-Matic
I had my Command replaced about 2 years ago when it first started happening and that turned out not to be the issue. My warranty doesn't cover the camera for some reason. I'm going to call today and see if there's anything they can do. How much do you want?
Old Sep 20, 2019 | 09:23 AM
DaleB's Avatar
Veteran: Army
2023 S500
If it's glitching and intermittently going black, chances are it's not a bad camera but a bad connector. I've had the same thing happen on my truck from time to time, and once or twice on the Mercedes. Almost always when there was moisture present from rain, washing, heavy dew, etc. The cameras are fine, it's moisture occasionally getting into the wiring or on the board. A little disassembly, cleaning, and sealing is on my to-do list.
Old Sep 20, 2019 | 01:43 PM
konigstiger's Avatar
'71 Pinto
Check line for kink or break, compliments of 604benz: https://drive.google.com/drive/folde...TVPTFZhemtMSDg
Old Sep 20, 2019 | 03:06 PM
2007 CL550
Let me know what you decide on replacing. I've got that wire as well as the camera.
Old Sep 21, 2019 | 12:51 PM
Timo K.'s Avatar
S212 E220 CDI -11, V221 S500L 4-matic -07
See this:
https://mbworld.org/forums/s-class-w...l#&gid=1&pid=3
I had exactly similar symptoms as above in post #14, got the broken cable fixed and the back up camera is working again
Old Sep 22, 2019 | 02:38 AM
bigkev21's Avatar
2010 S550 4-Matic
Thanks, I'll try this first.
