Telematics update
Is P/N A2218270065 what I want?
Will there be any part of this process that will require a login, like SCN coding does, or can I do it by myself, off line?
How risky is it to do this -- is there a significant risk of the upgrade screwing up the COMAND system and leaving it worse off than it is now?
Lastly -- anyone here have the CD I can borrow or download? I see a downloadable copy on Fleabay for under $10, seems pretty cheap (albeit of questionable legality, I'm sure).
DIsc is about $20 from the dealer.
As far as bricking the COMAND, there is a chance that could happen, yes. Is it likely? No. It takes about 45 minutes to carry out if all modules on the MOST ring need an update. You can do it while driving, or connected to a 40+ amp charger.
If it fails while updating, it will fall back into Bootloader mode and continue where it left of in most cases, just as a Navigation Map disc does.
If the idea has crossed your mind about updating the Navigation Maps from a "never used backup" copy of the DVD, be warned that with the age of the optics and the questionable quality of the media you will get, the chances are greater than not that it will likely fail transferring a few GB of data to the internal HDD. Not to say it isn't doable, but be aware. If it fails, it falls back to the previous map, and no harm is done.
The telematics was shall I say, a little sketchy with my setup. It's been a few years but I remember it took me several tries for it to "take off" and upgrade so to speak. And yeah, it was right around 45 minutes.
