Trickle Charging Consumer Battery - '07 S550
Old Oct 23, 2019 | 03:29 PM
HamMan's Avatar
2015 E400 Cab - 2013 GL350 - 2013 ML350 - 2006 E350 - Old Jeep
Winter storage time...
Car will be sitting for 5 months.
I am being challenged attempting to remove/locate (seeing) the consumer battery.
What I need to do is trickle (Battery Tender) charge the battery until May.
Please advise me on the correct thing to do...
Remove battery (I need instructions to uncover its location)
Or
Connect to a cable (under the hood, near the starter battery?)
I plan on covering the car but if I need to keep ventilation around the car I will just wash it (again) in the Spring.
Thank you!
Old Oct 23, 2019 | 04:21 PM
DaleB's Avatar
Veteran: Army
2007 S600
My uneducated, un-researched opinion which may well be wrong:
Lots of AGM batteries have been killed by the use of an inappropriate trickle charger or battery tender. I'd use a smart charger suitable for AGM batteries, like this one: https://no.co/g3500. It's what we use for the Odyssey AGM battery in the airplane.
Old Oct 23, 2019 | 10:16 PM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
Get a CTEK, they make the one that Mercedes sells for this purpose.
Old Oct 23, 2019 | 11:05 PM
tx170754's Avatar
S560/SL550/LS460/Q70L 5.6 AWD
I have stored my CL and SL using a CTEK connected to the main battery (using the connectors under the hood for the CL and direct to the battery in the trunk for the SL) never had a problem. Your car is similar to my CL so this us what you can use.
Old Oct 27, 2019 | 08:02 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
I recommend these as well, or follow the procedure to turn off all electrical consumers:
https://resources.mbdx.us/files/pdf/..._functions.pdf
Yes, the instructions do say to leave the key in the EIS, but only you know if the vehicle would be stored in a secure location. Once this is done, you can safely disconnect the ground wire in the trunk that is easily accessible without fireworks due to the draw of the control modules still awake, or possibly leave it connected, without any current draw from the system from devices such as the Alarm, etc.
Old Oct 27, 2019 | 08:10 AM
Polar Bear's Avatar
Or
Thank you!
Connect the charger to the negative post to the Starter battery under the hood, and the positive to the tall bolt that is revealed when the cover is removed from the electrical connection points to the left (looking at the vehicle from the front) of the starter battery. There is one taller than the rest - this connects to the consumer battery in the rear. The should be outlined in the manual.
