W221 2010 S400 Hybrid w intermittent no start
My S600 has Keyless-Go. MOST of the time you get in, push the brake pedal, hit the button, and it purrs to life. All good. Once in a while, totally at random, you press the brake, push the button, the dash light sup, and... nothing. No engine start. I fought this for a while, even replaced the starter thinking it could be a bad starter relay. Nope. Apparently it's a Keyless-Go issue. If I pull the KG button and use the key, it's an instant start, every time, no matter what. If using the KG button, sometimes it starts immediately. Sometimes you just have to hold the button in for anywhere from (again, totally random) a second or so, to as much as 4-5 seconds before it starts.
I'm sure it could be fixed. I'm equally sure I don't want to pay the bill that would come with fixing it. Since I know the workaround, it's a minor thing. Again, maybe not at all related to what you're seeing, but it might be something to try.
What was the outcome? Does the car still do it periodically?
