what happened if you place fuse in the empty location
I was wondering, about some empty fuses space in the fuse box if I could place fuses on them will that make any problems? I feel I am missing fuse but not sure if I place in the empty fuses as it shows in my fuses diagram will that make a load on the circuit ?
You should be able to see if it has the fuse connector both sides, sometimes if the car is not going to have a option it will have the battery side of the fuse there but the wiring side will be missing.
Just throw the recommended fuse in it, you cant blow anything up, the circuit is set to take the load and if there is a short it will blow the fuse.
Like for example my sedan has a sunroof, the fuse is in the sunroof spot in the fuse block, my coupe does not have a sunroof, but it has a sunroof fuse spot in the fuse block with no fuse, so unless your car has every single option fitted from factory it will have empty fuse spots in the fuse block.
