Possible Command Issue?
Since yesterday command screen has been acting weird, when I have it on Audio with radio dials in the middle of the screen, the joystick cursor won't stay up or down to change it to Navi or Phone in the top of the screen and to change audio options in the bottom of the screen.
I can use the Navi/Phone button on the center console without any issue, and when command screen is anything but Audio, the joystick works fine.
When I checked the battery voltage thru instrument cluster using secret menu, it was at 11.9 to 12.1 and I thought that the battery may be the culprit although it's less than three years old MB battery.
I was ready to go buy the battery but when I checked the voltage directly from the trunk, it was 12.4 to 12.5 which I think it's more than fine.
Alternator looks fine with 14.0 volt with engine on.
Another issue I've noticed is that when I answer the phone thru command, I can hear the other party but they can't hear me thru command.
Also, the radio sounds fine before answering the call, but the sound doesn't come back after I hung up the phone until I turn off the power of the command and turn it back on.
Does anyone have a clue where to start?
Thank you
I'll update here in a couple of days.
Thank you for your help.
