Driver Side Mirror Signal Lamp Failure (Quick Fix?)
Old Jan 28, 2020 | 12:35 PM
Xfireracer's Avatar
2017 C63S Coupe, 2001 SL500
Hi Everyone,
Long time lurker here. I have a 2007 S550 and I have problem with the Driver Side Mirror Signal. At one point it used to work but intermittently fail, now but this past summer it stopped working completely. I replaced the light which was quite easy to do, assuming the bulb burnt out, and I used an OEM part but that didn't solve it.
Is there a fuse I should look at? I've read it may be a SAM related issue? So is there is a quick fix or is it a sign of a bigger problem?
Thanks in advance!
E
Old Jan 30, 2020 | 11:38 AM
Xfireracer's Avatar
Bump!
Old Jan 31, 2020 | 07:47 PM
lkchris's Avatar
'10 CL550, '12 GL550
When this happened on my GL, it was the wiring. Whole new mirror internals required ... at least those the wiring goes to.
