malfunction light on........please help
Old Jan 29, 2020 | 08:24 AM
Anthony Hughes's Avatar
s class w221 320 cdi
Unhappy malfunction light on........please help
i have spent last month on car..........cant move it its sitting on the floor.........checked all 3 level sensors on a star scanner all ok.........my problem is compressor wont run
i have replaced air block and compressor.......checked all fuses.......40 amp no 56,.......15 amp no 46 and relay replaced .....new five pin relay......am getting a malfunction light and car rising fault.....? any ideas would help.....thank you tony.
Old Jan 29, 2020 | 09:04 AM
konigstiger's Avatar
'71 Pinto
You do not reference fault codes so I assume, surprised though, that there are none. Given this situation some additional things to consider checking are compressor harness, and control unit (n51) connections.
Old Jan 29, 2020 | 09:29 AM
thanx will try that
