Airmatic issue
(fuse 56 located under the bonnet) After fuse has been changed pump started working again. The only problem is that 3 struts rising but one (rear right) only rises to normal ride level (it’s actually a bit lower than other struts but don’t sink, no leaks etc and car is still drivable) and also won’t rise to high position... and “malfunction” message comes back on dash again..
Anyone fixed similar problem? Before I had this issue with burned fuse all 4 struts was rising as normal.
a score along the length allows air to leak, check with bubble bath at valve block for Right Rear feed
there's a diagnostic test in STAR 10 bar in 30 seconds, I expect yours won't make 6 bar in 10 mins - prob worn out due to manu fault from DOB
what miles? struts die
