MOST ring fails on hot days
Can anyone provide me some information on the MOST ring in the 2011 S550? I have a MOST bypass loop, so if I can get a list of components on the ring and their locations, I could probably try and bypass them next time the MOST ring dies. This should help me isolate it down to one component that's overheating.
if so its the amp in the boot that's dying, they all do it
and if you open up an new one vs a dead one they look the same, you never see the cause of the failure... if you clean of the dust on the old one (and we not talking about water destroyed one just clean used vs new)
they went from 2 battery's, a small one under the bonnet and massive 25kg hidden one in the boot,
in later cars these tend to have one big battery in the front and one aux battery (somewhere) and by the big battery the control module sits beside it and they go wrong... and cost a fortune
2215400401
dose the 09 have it
if it shows in diagnostic, you may be able to see live data of the cam position as you turn it over..... might want to be careful it doesn't start whilts playing...
