Replacing ECU - what's involved?
Old Jun 23, 2020 | 08:54 PM
pmercury's Avatar
member
CL
Originally Posted by MBENZTECH
Again, the engine installed in DaleB’s S600 DOES NOT need injector coding. It uses manifold injection. You’re trying to prove a point that does not need to be proven. The whole point of helping is to provide the correct information according to their vehicle.
by the way
it would be nice that you post a list of models that do need this data to be inserted
that would help the community
Old Jun 27, 2020 | 03:01 PM
DaleB's Avatar
Veteran: Army
2007 S600
Well, today I took it out for another run. On an empty stretch of highway I hammered it full throttle from a slow roll to 100+ a couple of times. No hesitation, no misfires, no codes. I'll continue to run fuel injector cleaner through the system for a while at least, and keep it up periodically as a preventive measure, but it looks like the problem is fixed. Well, THIS problem anyway. Now if I can just figure out why it likes dumping coolant overboard, I'll have a reasonably reliable vehicle. For a while.
Old Jun 28, 2020 | 08:25 AM
vettebk's Avatar
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, 2017 Mustang GT, 2023 300C, and a 2019 Lincoln
I run a large plastic bottle of techron added to a full tank about once a month. I think it helps.
Old Jul 28, 2024 | 07:36 PM
austin1chase's Avatar
2008 Mercedes S550 4Matic
I am in need of a new ECU. I still haven't purchased a used donor yet. I have Xentry so I can program a virginized one, but if you also have Xentry/DAS, I'd rather mail you both ECUs and have you clone the donor all at once. Let me know how you'd like to proceed.
Old Jul 28, 2024 | 07:40 PM
Hello DaleB.... the used ECU first has to be virginized and only then it can be coded to the car. If you send me the Original ECU along with the Used/new one I can do everything on the bench. It will have the latest software update/SCN coding done with connection to the server. I will have all FBS3 data transferred from Original ECU.
Old Jul 28, 2024 | 09:17 PM
Originally Posted by antiguangenius
if you send me the donor I can make it happen if you have das, if you don't have das I need both ecu then it will be plug and play
I am in need of a new ECU for our 2008 S550. I still haven't purchased a used donor yet, but I've been looking on eBay. I have Xentry so I can program a virginized one, but if you also have Xentry/DAS, I'd rather mail you both ECUs and have you clone the donor all at once. Happy to discuss.
Old Aug 1, 2024 | 05:02 PM
  #32
MrBenzGuy's Avatar
w221 s550 2011 4matic
Hello will you still do this service?
I have a bad ECU - please ping me - looking to understand costs.
