How to make a headrest straight?
Has anyone figured out a way to correct it? For a while I've been driving my S600 with a simple correction of removing the top seat tubes which hold the headrest. It allows for the headrest to sufficiently move back, but it's wobbly and looks ugly without the plastic finishing around the mounting holes. I've disassembled the headrest and tried to bent the two metal tubes which go into the seat, putting one end in a vice but it's quite stiff and does not bend. Before I put a few feet extension tube for more torque and break something, has anyone figures out a simpler and cleaner way? Does anyone else see it as a problem?
(To preempt all the "don't touch it, it's for your safety, dummy!" messages, it's not for MY safety as constant bending the head forward makes me uncomfortable and more prone to causing accidents :-)
Thanks!!!
they tilted and you could get it just right and have it support your head
while you drive, like it was a "HeadRest" or something.
Wish they hadn't changed them.
Now the seating position is almost as comfortable as in the W124 and W140 :-). It just needs a bit more firmness in the seat itself, but that will be another project...
