Ride Hight
thx
check all the level sensor link rods are moving freely before you try (they seize and snap off, and a seized one will lead you astray. Front left front right to side to side, one rear does both sides.... then drive is about and recheck... they wander
in comfort about 2 inches between the top of the tyre and the bottom of the wheel arch is normal all round... if u can get within 1/2 inch you'll be doing well.... ABC can be inside 1mm each corner.
there's a post with TIPS document about the RR issue - this might be the issue you have
they damaged the RR pipes building the car and it has a tiny air leak to the pipe with a score the whole length of it. The whole pipe needs to be replaced. But usually you get the leak 2 to 3" from the valve block.
The odd thing is, this is the exact issue on my car but on the left rear.... so did they damage the pipes on all cars on the opposite side to the steering wheel or something else is wrong on mine.....
https://mbworld.org/forums/attachmen...8772_ver_2.pdf
FYI at 7 years you should just replace all the link rods to all three level sensors as a precaution against breakdown... I thought mine was OK but the rear just snapped clean off and the car collapses to the ground and you can't drive it.... very dangerous and extremely inconvenient...
