Screw in the front tire
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, 2017 Mustang GT, 2023 300C, and a 2019 Lincoln
So I took my 2007 S600 V12 out for a spin in the nice weather. First thing I hear is a thump thump thump coming from my front end, Almost sounded like the tire had a flat spot. I pull over, and sure enough, a real nice sheet metal screw is embedded in the first sub-section nearest the side-wall of the Michelin tire. I grab a set of vice-grips and unscrew that little metal varmint. Holding my breath, I wait to see if it leaks air. So far, so good. When I got home, I stuffed the hole with RTV silicone. You could plainly see the outline of the former screw in the tire.
Will the tire leak?
Will the tire leak?
