Coolant loss..Where is it going?
2010 CL550 4matic, m273 engine, 130k miles..runs great, but lately coolant low message comes and goes sometimes when taking a curved ramp at decent speed. Now today it came on as soon as I started the car. Obviously added some coolant to the correct level and will update. As for now, there are no leaks anywhere, that I can see..should I be scared?
Scared? Probably not. Have you added coolant just once, or more than once? If once, then watch and see what happens. If more than once... you have a leak somewhere that needs to be found.
I got under mine and found evidence of the coolant leak I had been chasing. It would only lose coolant overnight after driving it, or so it seemed. But, there was evidence of a leak under the driver side turbo. A $7 O-ring and several hours of work fixed it. That was just my situation. There are dozens of places leaks can occur, some trivial and some catastrophic. Just do some basic troubleshooting and observation. That blue coolant generally leaves ample evidence of where it’s been leaking.
Take a close look at the engine oil and other obvious signs you should be worried about. Otherwise I would start with the usual suspects that are easily accessible like the radiator and hoses etc. If you have a slow leak it’ll be hard to find as it gets blown all over as you drive, sometimes leaving no evidence behind. 7 months is a very slow leak if you ask me.
COUPCONNOISSEUR (10-23-2020)
Keep an eye on the coolant. Only two possibilities:
- external loss (leak)
- internal loss (consumption)
External losses eventually should all be visible with careful and prolonged inspection.
Internal losses can be found first of all by noticing exhaust pipe smell, bubbles in coolant reservoir while engine running and oil sludge the color of milk chocolate.
