Calibration of the ABC vertical acceleration sensor?
After stopping and diagnosing the system, it turned out to be failed right front vertical acceleration sensor. As it was Sunday and 500 miles away from home, I simply disconnected the sensor, the car leveled nicely, and I drove home with "ABC Failure" message and without functioning ABC. Luckily the computers did not turn off the drive train power, just the ABC functions were turned off and the car was very stable - just a bit more stiff and bouncy.
So I bought a new sensor, put it in, the ABC Failure light is gone, I start to drive and the car goes into the rodeo by itself. So I stopped and disconnected the sensor again, not having time or desire to find out where it leads itself.
QUESTION: Has anyone replaced a vertical acceleration sensor and is the car self-calibrating itself with the rodeo after that? Or is the rodeo an indication of some problem? Or it should be manually calibrated with DAS? Any other thoughts?
Thanks!
Just my.02
the other thing is these need a complete 30k mile or 2 year fluid and filter change if you want it to survive longer than 10 minutes.....
if this hasn't been done things will have worn and seals will have been damaged... requiring very large amounts of money
I hooked it up to DAS. The voltage reading on the new sensor was way off compared to the others. I think it read 1V or so lower. From what I recall I don't remember seeing any calibration steps in there. About the only one is ride height.
I ended up throwing my old one back on. But yeah, it is crazy how they make the car react. With the new one on I drove about 100 feet and it was doing a full rodeo up front.
So we have a problem when either a brand new or old sensor is bad - I have had both cases, and it gives a voltage different than expected. This causes the car to try to compensate and it keeps on bouncing "rodeo style" without a success. If it happens, the voltages should be checked and another sensor needs to be purchased to correct an out of range voltage.
