(video) Replace the front brake rotor and pad
If you like my video, subscribe my channel.
One thing i would have done though is clean the Hub mating surface with a steel brush before mounting the new brake disc. You surface looked pretty clean but most people are not that lucky and it can make the new disc wobble.
Yes, the wheel hub should be cleaning, I just cleaned at last disc replacing one year ago. This discs are defective, so I have to replace them.
I have not looked at this in my car so my question is: The set screw n the hub/wheel-is it threaded to the wheel or the hub? If it is threaded to wheel then a bolt in this hole could perhaps be used to push the wheel out without hammering on it.
There is no any tip about how to gently remove the rotors from the hub on WIS of MB. So I have to spray some WD-40 to soak into the gap between rotor and hub, to loosen adhesion. And then lightly hit the rotor by hammer. I think that hitting on the bearing won't be greater than the impact of driving on the road.
I think😂All of the locking screw and the lug bolts are threaded into the hub, and all of the rotor and the wheel are thru holes, so there is no way to push the rotor out.
