Multiple periodic errors
Old Feb 13, 2021 | 11:19 AM
MasterHans's Avatar
S 500 4-matic
Hi
I've got a -07 S500 4-matic (S550 in US). From time to time a get some quite annoying errors on the car. Listing them up:
- Turning signals stops working
- Fuel gauge stops working
- Right headrest goes up an down
- Tire pressure sensors fails
- Parking sensors fails
These errors can appear one by one, or all together. Usually starts with the turning signals, an often after driving some kilometers.
In lack of a better solution, I changed the front SAM. No change.
Any ideas where to start?
Old Feb 13, 2021 | 12:24 PM
DaleB's Avatar
Veteran: Army
2023 S500
Laptop and DAS would be where I'd suggest starting. Otherwise you're just wandering around with a blindfold on and hoping for the best.
Old Feb 14, 2021 | 03:19 AM
MasterHans's Avatar
S 500 4-matic
I have spent a few hours with my Xentry, but I can't figure out what can cause all these fails to appear, at the same time. I has to be some sentral unit or communication point, that affects all these functions.
Old Feb 16, 2021 | 09:40 AM
Arrie's Avatar
So, what is common for all these errors? You replaced the front SAM but no help. I don't know but I assume all these devices come from the front SAM?
So, is it power supply to the front SAM or is it grounding problem with the front SAM? I would look into grounding connection(s)...
Old Feb 16, 2021 | 12:56 PM
BOTUS's Avatar
S500
parking sensors are on the rear SAM and I didn't spot any of your other's related to the front....
sounds like can bus fun....
Old May 11, 2021 | 04:08 PM
MasterHans's Avatar
S 500 4-matic
Another «fun» observation regarding this issue; the faults occurs when I turn to the left. When I turn the steering wheel to the right, everything returns to normal. Makes me think of steering angle sensor. Checked angle values, looks OK.
Old May 11, 2021 | 07:06 PM
Scoutino's Avatar
'07 S65 AMG
It could also be caused by something physically moving to the right when you turn left. Wire can shift position and short, or ground cable lose connection.
