Unlocking ECU for variant coding?
Old Mar 2, 2021 | 05:37 PM
George993's Avatar
2014 E350 Wagon, 2009 SL550 no ABC
Experts, has anyone seen DAS error 8.561.6067 when trying to reprogram ECU (ME17) using Adaptation -> Variant Coding option?
Google says the ECU needs to be unlocked first - how to unlock it on W221? Others say that the coding values need to be in a plausible combination - does it make sense? Thanks!
Old Mar 2, 2021 | 07:58 PM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
You can do this with Vediamo configured with a Seed Key or high acesss level, under Functions for the ECU look for DJ_Zugriffsberechtigung.
Old Mar 4, 2021 | 04:43 PM
George993's Avatar
Thanks EasyPhil , now trying to get Vediamo going.... (Would be nice it there was a way using DAS as well)
Old Mar 6, 2021 | 01:17 AM
mcypert's Avatar
2007 S600, 911 & XJ8
Phil and George, am I correct in assuming I can't update the Motor Electronics with just DAS?
My recent posts have been about my new-found "skill" of updating programming, which I have, by and large, not done. Discretion being the better part of cards...
Looks like George and I have similar S600's. My version currently looks like this:
It's running, I think, Oct 2007 software done by the dealer in Mar 2008. I have, again-- I think, newer software but don't know if an update would be useful... Especially, if I can't do it w/o Variant coding!!!
Regards... Mark
Old Mar 6, 2021 | 04:48 AM
BenzNinja's Avatar
Former Vendor
I can
playing around with vediamo without expert knowledge will kill you module
Old Mar 6, 2021 | 11:13 AM
George993's Avatar
BTW, I don't touch my S600 ECU, running fine so no point to fix it if it is not broken. My experiments are now with S400 - those seem to be broken by design most of the time, so probably can not make them any worse :-). But so far I have not been able to do any ECU changes.
Also my ECU Version shows: "UNKNOWN_VARIANT" and DAS complains about it. Was S400 ECU ever programmed at the factory with "UNKNOWN_VARIANT" or does it look like someone has been here before messing up stuff?
