Overnight rain w/ sunroof open
Old Jun 14, 2021 | 02:19 PM
ClasseMiaMadra's Avatar
2016 S212
Hello everyone. So the sunroof was accidentally left fully open overnight. And of course, it not only rained, it poured. The removable rear floor mats are soaked beyond capacity, meaning as they are lifted, water pours out of them The front seats stopped dripping earlier in the afternoon, but seating on them soaks your clothes, even after soaking what is possible with towels. My indy recommended to take it in ASAP so he can take out the floor carpet and dry /check /clean all the affected parts. Challenge is that the car is 200 hundred miles away from me and the indy, What is the suggested course of action from anyone who has prior experience or enough knowledge to advise?
Insurance will cover this as water damage and I could have it flat bedded. Is it worth this trouble? Or will running the heat on high with the AC on for a couple of day will dry it out ?
The car is a 2012 S550 4M with 120k miles on it and no problems at all.
Thank you.
Old Jun 16, 2021 | 11:43 AM
2016 S212
So I guess nobody wants to touch this.... My sentiments exactly... but I am concerned I am siting on a time bomb with all the modules that may be affected. Any input or prior experience would be very helpful.
Thanks again.
Old Jun 16, 2021 | 01:55 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Obviously drying components quickly would be the goal... it really depends on how bad it is or how saturated. I would certainly start my removing all the seats from the car and placing (not in direct sun) but somewhere warm with a fan placed to blow air across them.
Now with the carpet, I would pull any body plugs from below to aide in drainage. Use towels to squish and suck up as much water as possible. I would even remove trim around the doors to allow the carpet to be pulled up and away from the floor (allow air to dry from both side as much as possible). Again warm spot, lots of airflow from fans. May even consider totally removing the carpet if its that bad or modules are at risk.
A lot of work in any event.
Old Jun 16, 2021 | 05:21 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
I would have it towed ASAP to a local body shop and have them try to dry it.
You are right about ticking time bomb, this forum has a few stories about people buying flood cars and repairing them.
Position with your insurance company for total loss..flood. Start looking for replacement cars so you have something to compare.
Good luck,
Old Jun 16, 2021 | 05:39 PM
Arrie's Avatar
Why did Mercedes Benz disable the automatic sunroof closing if left open and rain is detected?
Can anybody tell any good reason for that?
Old Jun 16, 2021 | 10:57 PM
DaleB's Avatar
Veteran: Army
2007 S600
A good reason? No. A guess? My guess would be fear of product liability in the US. I suppose there’s a chance the sunroof could close on some numbskull’s hand or head if it were closing automatically. Yes, it could/would probably auto-stop and maybe auto-reverse, but it could leave a bruise and an opportunity to win cash and fabulous prizes in court somewhere.
Old Jun 17, 2021 | 09:25 PM
Arrie's Avatar
Wish I had the programmer to change some codes…
