What is this part called?
Old Aug 20, 2021 | 03:24 PM
WHPH28's Avatar
Depends on the weather
lol, forgive my lack of knowing the name but what is this part called (circled in red)? The piston is under it but what is this part or is this actually part of the piston??
The rear amg brakes don't have it, but the fronts do.
Old Aug 20, 2021 | 03:55 PM
BOTUS's Avatar
S500
is it the brake piston but with some odd idea to get air flow ?
normally -
calliper body
piston seal
dust seal
piston
bleed nipple + dust cover
pad
pad retaining bit
shouldn't be much else - you can have nasty split callipers with the bolts that hold it together of course and a seal between the parts... or single sided sliding garbage and the associated rot to let that happen (or on the back some form of park brake)
Old Aug 20, 2021 | 04:23 PM
WHPH28's Avatar
normally -
calliper body
piston seal
dust seal
piston
pad
pad retaining bit
This part looks like it sits inside of the piston separately, whatever it is.
Old Aug 20, 2021 | 06:27 PM
konigstiger's Avatar
'71 Pinto
I believe they are bellows. Searching 0014210986 only shows seals but if you search ebay for caliber 0034205383 or 5483 some aftermarket kits will show bellows.
Old Aug 20, 2021 | 06:39 PM
WHPH28's Avatar
Thank you for the information.
Old Aug 21, 2021 | 05:27 AM
BOTUS's Avatar
S500
bellows sounds like dust seals to me...
either way odd looking photo
Old Aug 21, 2021 | 05:46 AM
WHPH28's Avatar
Better pics so it's easier to see them. Not really finding much but as you can see they are only included on the front calipers, not the rears. Could be called "brake friction plates" based on this diagram but don't find much on those either.
I was going to order new ones so I didn't have to spend the time taping each individual one of them on every caliper to paint them.
Old Aug 21, 2021 | 10:44 AM
'71 Pinto
OK different caliper, do you have the caliper part #.
Old Aug 21, 2021 | 10:45 AM
WHPH28's Avatar
19.7661.04
Old Aug 21, 2021 | 11:34 AM
'71 Pinto
Support: https://www.bremboparts.com/america/en
Old Aug 23, 2021 | 02:56 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
I believe their a form of heat shield/shim... which is snapped on to the face of the piston. I've seen then on some older single piston calipers.
