No Aux in Comand, but hardware installed
Old Sep 16, 2021 | 10:51 PM
I Am Jacks Merc's Avatar
2008 S550
I just got a 2008 S550. There is no 'Aux' to select in Comand, although all the hardware is installed.
In the glovebox, I have:
- the 3 aux jacks. I've tried using the proper cable to the 3.5.
- a 30-pin connector with a CoolStream bluetooth attached. It has a light which is on (and I've paired with it successfully), so it must be connected.
But there's simply no 'Aux' to select in Comand, I've looked everywhere. I've tried selecting instead MP3, CD, DVD, but it just says they're all empty.
I've read the manual, scoured forums, but nobody seems to have this same issue.
Any thoughts? Thanks in advance.
Old Sep 17, 2021 | 07:51 AM
amgs63dxb's Avatar
W222, W221, W218, W211
sd/xentry or vediamo -> any soft for MBs can unlock the AUX menu. If connected at the back of the radio, you should be able to use it in no time...
Old Sep 17, 2021 | 10:21 AM
BOTUS's Avatar
S500
on much later cars this disappearing is quite normal - had a post where on the fifth time of trying it came back to life
it should be from selecting AUDIO, press comand knob to display menu and drop down to
Radio (FM, AM, LW, SW... but to select a different tuner - its another menu down to the bottom right )
Sirus (or DAB in Europe)
CD
DVD
MP3
Aux
it can be turned off (or on with dealer tools) its an optional menu - turned on where aux inputs exist (although you can enable and have the menu with nothing there to connect to and nothing is amiss)
Old Feb 3, 2022 | 01:55 PM
2008 S550
Thanks for the help. So the plot has thickened. Update:
It's not just the AUX, it's other functionality including the back-up cam, and seat massage controls. NAV also thinks I'm 400km away from where I am. Every once in a while COMAND turns off and restarts.
Took it to the dealer, they can't get the COMAND update disc as it's discontinued, tried an incorrect disc to no avail, and provided no other solutions (not a lot of faith in these guys based on experience).
Called to Mercedes Canada (beer league customer service centre), she suggested I sell the car and get a different one where everything works. Thanks Mercedes.
So the only things I can think to do:
- reverse engineer the issue. How could this have happened? I've checked and reseated all relevant fuses.
- anyone know the part number for the disc in hopes I can find one on ebay? The update, not the NAV telemetrics.
- swap the disc unit which contains the firmware ($$$).
Thanks in advance for your help.
Old Feb 5, 2022 | 10:34 AM
megacrazy's Avatar
CLK55 W209, CL63 W216
Sell the car and buy a new one . Typical Mercedes BS.
You need access to Xentry to diagnose what’s going on. There are many different firmwares for these units and you should check which one you need in order to reflash/update. Fortunately not everyone stores/orders CDs like the idiotic Mercedes dealers. Some people store stuff digitally. Imagine that. Some people can even share firmware online with others that need it. Crazy futuristic stuff right there.
I feel sorry for the latest Mercedes models that are loaded with even more tech. 7 years from now they’ll be the biggest money pits ever when all the individual modules start failing because of poor solder jobs, coding and other typical planned obsolescence crap. You might not even be able to open the door cause the motor that pops the door handle might not be manufactured anymore.
Old Aug 13, 2023 | 06:40 PM
2008 S550
Thanks for the help. Situation ended up getting resolved by replacing the COMAND unit with one from the wreckers ($200 CAD). There's a couple little glitchy things left, which I understand is due to the VCM not being programmed to the new COMAND. AUX is back , back-up camera is back, and it doesn't reset itself anymore.
Old Aug 14, 2023 | 07:45 AM
clb0099's Avatar
‘16 Mercedes GLE450 amg,’15 Mercedes gla, coupe,’07 Mercedes w221,’12 Audi A
I may have the telematics update disc somewhere.
QUOTE=I Am Jacks Merc;8830259]Thanks for the help. Situation ended up getting resolved by replacing the COMAND unit with one from the wreckers ($200 CAD). There's a couple little glitchy things left, which I understand is due to the VCM not being programmed to the new COMAND. AUX is back , back-up camera is back, and it doesn't reset itself anymore.[/QUOTE]
