Stripped Screw
just repaired my keyless go issue recently which required removing the door handle.
Good luck.
how are you able to see the turning? Mine was blind.
Its possible the bolt bolt is defective.
might need to go at it from inside by removing the panel.
Can you get a pick in the area where the bolt locks the handle? If the bolt is broken you might be able to unlock the piece with a pick??
https://www.benzworld.org/threads/ke...#post-18271057
When the screw is turned the bracket slides in the bearing bracket either tightening or loosening the lock cylinder. Not sure if this can be purchased separately. Found a bracket on Ebay for $12 bucks. Took a couple of hours to swap out but saved at least $300.
