door ambience light?
Old Oct 27, 2021 | 06:10 PM
riv-stage 1's Avatar
2012 s550 4matic
the passenger side rear door on my 2012 s550 ambient lighting is NOT working like everywhere else. I suspect it wasn't working when I purchased it in April but didn't notice it till later. Is there a known fault that leads to this situation? I haven't found anything relating to this failure, and, The Star system hasn't triggered any fault codes that I've seen.
Old Oct 27, 2021 | 11:08 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
Assuming you mean interior lights on door panels, Yes, have same issue on driver side rear door, but only on 2 colors. Works on amber, not blue,etc. DAS says ground issue. Since I am happy with amber I have not bothered to tear the door apart. Check your grounds "?
Old Oct 29, 2021 | 02:51 PM
Arrie's Avatar
Does it require to remove the door panel to get to the ambient light strips? Mine are rattling bad and I want to add some cushion inside to stop the annoying rattle.
Old Oct 29, 2021 | 03:33 PM
konigstiger's Avatar
'71 Pinto
File Type: pdf
File Type: pdf
File Type: pdf
Old Oct 30, 2021 | 11:57 AM
Arrie's Avatar
Thank you konigstiger.
It is what I was worried about. The whole door panel has to be removed for access to the light strip.
Old Oct 30, 2021 | 07:44 PM
MBCO's Avatar
Not to worry, not an overwhelming job. I just did my Sl R230, driver door panel removal in order to replace a broken metal part in the door handle. Very similar procedure.
Be be sure to use your wedge on the panel clasps as directed. They can break.
Keep us posted.
