'12 S350 W221 Low Idle RPM
Old Nov 23, 2021 | 10:03 PM
steaua1986's Avatar
GL350
I have this annoying issue on my car. Idle runs at 560-580rpms and with a noticeable (diesel) vibration and nobody can figure out why. On this model ('12 S350) it should be 750 rpm. Once in a blue moon, especially when it is cold outside it goes to 750 and runs very smooth for a few minutes but I can't pinpoint what triggers that. Btw, when I say cold, I'm talking about the outside temperature, not the engine ... the engine is warmed up to where it should run. STAR computer scan shows no error codes and looking at live data, parameters are all within range with the exception of idle rpm. All filters changed, DFS is clean, EGR is clean. Injectors checked and run fine. Other than at idle, engine runs great, lots of power and smooth. This has been going on for years now. I even took the car to a Mercedes dealer and they couldn't figure it out either.
Anyone ran into this or has any suggestion of what else could I try?
Old Nov 25, 2021 | 07:45 AM
Senecat's Avatar
1983 Nissan Shltbox
Bump up the idle with Xentry and see how it responds.
Old Nov 25, 2021 | 12:56 PM
steaua1986's Avatar
GL350
I don't think that's possible on the diesel engines. Gasoline would work but not on the diesel.
Old May 5, 2023 | 03:51 PM
denyoe's Avatar
mercedes s350
have you found the solution? My father has the same car and exactly the same problem.
Old May 20, 2024 | 03:49 PM
AndreiR's Avatar
W221 S350 4Matic OM642.868
Did anyone got to solve this problem? I am still searching for a solution.
Old Jun 3, 2024 | 12:00 AM
artim808's Avatar
2012 S350 Bluetec 4MATIC; 2011 ML350; 2005 C230k;
It’s not a problem, this is by design. Increased idle RPM to 750 is only if:
1 - engine is cold so it can heat up faster
2 - DPF regeneration is in progress
3 - battery voltage level is too low
4 - cabin temperature is too high so A/C can run more efficiently
If you have abnormal vibrations, you may check your engine mounts. If the engine is running rough check injectors. But your idle RPM are perfectly fine.
