Headlight bulb.
Old Dec 9, 2021 | 07:18 AM
tbilisi79's Avatar
Headlight bulb.
Can someone confirm the headlight bulb number?
08 s550 with night vision. Do I have Bi xenon or xenon. My hi beam and low beam comes out the same headlight housing.
Is it D1S?
Any specific place to buy them from? FCP? AutohausAZ.
and is it 4000k or 5000 k.
My passenger side headlight started turning pinkish in color. I assume its on its way out.
Thanks in advance
Old Dec 9, 2021 | 08:40 AM
konigstiger's Avatar
'71 Pinto
Bulb is going I suggest replacing both sides so they match. Need VIN to supply MB part # searching this will also pull compatible aftermarket if this is your intent.
Old Dec 9, 2021 | 08:53 AM
tbilisi79's Avatar
Thank you. I was gonna go with a Phillips brand and at this time I just want to make sure they both work, I can swap in the other side at another time.
Vin is. WDDNG86X38A208177
Thank You.
Old Dec 9, 2021 | 09:05 AM
'71 Pinto
See attachment.
File Type: pdf
File Type: pdf
Old Dec 9, 2021 | 09:15 AM
tbilisi79's Avatar
See attachment.
Thank you.
Dealer wants $250. What a racket.
Old Dec 9, 2021 | 12:45 PM
BOTUS's Avatar
S500
most cheap one's on ebay are fake Chinese rubbish and can cause fires
Philips make some of the best headlights for quality of beam produced
bi-xenon is a term relating to a metal strip that flips inside the light unit to switch between dip and high beam - it does not mean 4 lights (two per side)
Old Dec 9, 2021 | 12:47 PM
tbilisi79's Avatar
Thank you.
I got a Phillips one from Rock auto, $54. Same one on FCP was $84. With one day delivery it came out to $75 or so.
I just hope I can instal the bulb without ruining anything.
If the new bulb is too different looking compared to the driver side, Ill get a new bulb for that side as well soon.
Was weird to see one side go purple all of the sudden with a few flickers here and there.
Old Dec 9, 2021 | 01:19 PM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
I don't trust Amazon bulbs. I trust Rock Auto. My $0.02.
Old Dec 9, 2021 | 02:50 PM
vettebk's Avatar
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, 2017 Mustang GT, 2023 300C, and a 2019 Lincoln
You are totally right. If you give the Chinese a good spec requirement, they actual can make a nice product. But if you are competing on price only, they will make it as cheap as they can which is never good. I have seen metal meshing parts with no lubricant to save a dime; a disaster waiting to happen in 10 months or so. For my S600, only German or OEM parts will do. And be careful, I have recently seen Chinese parts inside a German box labeled made in Germany. The box was made in Germany, not the part!
Old Apr 21, 2022 | 06:33 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
I'd like to change the Xenon headlight bulbs in my car. They work, but they're 14 years old, and probably due for some shinier news ones. What's up with the death warnings and 25,000 volts labels? I see people on YouTube changing theirs with seemingly no problem. What would I have to do wrong to end up getting fried doing this? I assume I disconnect the starter battery? Or battery in trunk?
Old Dec 29, 2024 | 10:45 AM
e.vandepavert's Avatar
Please some help and instructions
[img alt="see the one failing
"]https://cimg0.ibsrv.net/gimg/www.mbworld.org-vbulletin/1600x900/headlight_cls_w218_0eba1a55ecd8e380e80937a8cda4b81 8246ca02d.jpg[/img]
see the one failing
I have also a headlight challenge, I need to replace the bulb (so not the mainlight bud the small one).
My Mercedes (X) W218 form 2013 Left hand drive needs a replacement of a bulb on the right hand side its easy acces bud on the drivers side (left) not. Can not find any how to manuals who can help me please.
