Tires
Old Mar 8, 2022 | 04:37 PM
charmessence's Avatar
2010 S550
Tires
I researched some old forum posts about the best tires for w221 and am looking at MICHELIN PILOT SPORT A/S 3+. Does anyone know anyone with good deals? Looking at old posts there were a few people who said to contact them but that was from nearly 10 years ago....
Old Mar 8, 2022 | 06:09 PM
vettebk's Avatar
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, 2017 Mustang GT, 2023 300C, and a 2019 Lincoln
tirerack.com. I have PS3s on my S600 and PS4s on my mustang GT. Great tires. Just run them at a higher normal pressure on the W221 to prevent pot hole blow outs. I run my fronts at 38 and and my rears at 40.
Old Mar 8, 2022 | 07:45 PM
joeshannon095's Avatar
2018 S560, 2004 SL500, 2014 S550 (SOLD), 2012 S550 x2(SOLD), 2007 CL600 (SOLD), 2007 S600(SOLD)
The margins on tires are paper thin. If you're looking for new tires then there isn't going to be a big difference between where you buy them, sans some sort of clearance item or rebates. I have Conti Extreme Contact DWS06 Plus currently. Replaced my run flats. The difference is night and day. Also had the Michelins you suggested. Fantastic tire as well. Little stiffer but the steering response is better. I went with the Contis as the ride quality is great while still maintaining excellent grip and they're extremely quiet.
Old Mar 8, 2022 | 09:41 PM
2010 S550
thanks! As far as the tire pressure sensors go, I’m looking to replace these... should I go oem or is there a aftermarket brand that works ?
Old Mar 8, 2022 | 10:26 PM
JJKCMO's Avatar
Exige S | V70R | CTS-V wagon | JKUR | 13 S65 (Mocha/Armagnac)
PS4s and Alpins on our S65. Both are outstanding tires.
Old Mar 9, 2022 | 05:33 AM
WHPH28's Avatar
Depends on the weather
I love the AS3+ but since they stopped making them for my front size (255/35/20) I changed over to the AS4's. They have been great so far. I just order online and pick them up from Tire Rack since you get a 10.00 discount per tire for pick up.
Old Mar 9, 2022 | 12:21 PM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
I have a set of AS4s on my E55 and also now on my S550. I do recommend them but I also haven't accumulated more than about 5k on the E55 tires and a little over 4k on the S550 so it's early to make a judgement. There is some tread noise but I am OK with this because I wanted a sportier all season, not mush. I will rotate to the max ability which means a full rotation on the S550 and side to side on the E55. Tire pressure wise I tend to run near stock or a little above on both. I have the base 18s on the S550 so fortunately I have some sidewall.
Old Mar 10, 2022 | 02:44 PM
Chachd72's Avatar
S550
Are you in the US? In the US you won't find better priced tires than at Costco but with a limited selection.
. Tire rack also has good prices. I have a 2011 W221 and just put a set of Michelin Cross Climate tires on but I had to go with a 245/45/18 vs OEM size of 255/45/18. I'm not an aggressive driver but these seem to handle well, are quiet and ride well. Size difference based on Revs per mile are 768 for 255''s vs 780 for 245's.
Old Mar 10, 2022 | 02:53 PM
2010 S550
I am in the US. Also searching for some good quality wheel spacers (preferably those that bolt in) but am unable to find the bolt on/in spacers in 8mm 5x112
Old Mar 14, 2022 | 09:13 PM
2010 S550
Found these spacers and wanted to ask if they are good for the w221?
https://www.ecstuning.com/b-ecs-part...411ecs01a08kt/
As well they will bring my aftermarket et35 rims back to the factory of et43. Silly question but have to make sure, would I need to purchase a different size lug nuts or would my lugs I have now work due to them being the correct length for oem et if 43
Old Mar 21, 2022 | 03:27 PM
doni01's Avatar
2013 S550 4MATIC
They are good but I personally will go with H&R. Also you have the offset thing wrong. Factory our cars come with 43 offset. Now you have gone with 35 offset. That means your wheels are sticking out 8mm at the moment. So if you put a 8mm spacer you will be sticking out 16mm and will be at 27 offset overall and not the other way around.
Old Mar 24, 2022 | 01:58 AM
lkchris's Avatar
'10 CL550, '12 GL550
It can be sort of interesting to learn which tires for your car get listed at …
mbusatirecenter.com
Old Mar 24, 2022 | 11:41 AM
2010 S550
I went with the Michelin AS +3, as ebay had a deal for brand new $850 shipped
Old Mar 25, 2022 | 08:52 AM
BenzV12's Avatar
W212 FL
Nice, hopefully they will serve you well
