How do I open trunk with no power or Key? 2009 S550
I thought about that too. The only thing is there is no access through the back seats. I could try to drill a hole in the wall where the center arm rest is. But I’m also not sure if that emergency button will power up due to it being in a flood.
) would trigger the alarm and lockdown the car until it was started with the original key but clearly not an issue here.Also, boot releases only exist in North American models as far as I’m aware. If you fold down the rear centre armrest, you can access the fusebox and then push through to the boot (the panel takes a lot of force and might break) so you should be able to feed a wire loop or something through.
Be careful cutting through as the seats don’t back on to the boot/trunk directly - there is a space a few inches deep that houses several computer modules and the main battery back there!
