Torque converter slipping CL550. 722.9
Old Mar 23, 2022 | 03:35 PM
Nurione's Avatar
W140 w209 c216 c126
Hi,
After 15 minutes of driving the car goes into limp mode, the trottlebody only opens 15% and has no power when I press full throttle, it shifts into a lower gear and revs more but does not accelerate.
It lasts for a minute and then power returns or I have to shift it into neutral and back in drive power also comes back after driving.
i see in the star diagnose my torque converter is slipping when i drive 200-250rpm's i think it should be <50rpm normally.its slipping to mutchI've already changed the oil and filter and also replaced a torque converter, but no difference
Pulled codes P2783 (torque converter temp too high) and P0741 (torque converter clutch solenoid performance or stuck off).
i think i can do 2 more things replace the torque converter solonoid or the valvebody circuit board/conductorplate.
does anyone have an idea.
my car is cl550 2007 trasnsmission is the 722.904
Old Mar 23, 2022 | 05:18 PM
WRC-LVR's Avatar
2012 E350 Cabriolet now SOLD to my son
the valvebody circuit board/conductorplate. ..its old and they fail with age. Lots of threads with this
Old Mar 24, 2022 | 02:13 PM
BOTUS's Avatar
S500
TC's self destruct
Old Jul 2, 2022 | 01:03 AM
YoungBosnia's Avatar
2007 CL550
Did you ever resolve this issue with yours? What did it turn out to be? Have the exact same problem with mine
Old Jul 2, 2022 | 01:04 AM
Nurione's Avatar
W140 w209 c216 c126
I think solonoids broken
Old Jul 2, 2022 | 01:06 AM
2007 CL550
did you end up getting it fixed?
Old Jul 2, 2022 | 01:48 AM
Nurione's Avatar
W140 w209 c216 c126
Yess i do another tc solonoid in and it was great for 1 month.
now i almost almost te same problem again...
my transmisiomn has dirt inside and that gos in the solonoids.
debris from the trans come loose..becouse trans was many thimes to hot
