S211 Airmatic Code 5508
I have checked fuse and relay for compressor, it's OK. I guess it might be the compresssor is not function well, but I am not sure if could be a problem with a sensor, or other reason. I would appreciate if someone could help.
Information from iCarsoft:
BENZ_EN_TEST_00004>E(211)>From 06-2005 to 05-2006>T-Model>Gasoline>211.256 - E 350>Manual>Suspension>Read Fault Code:
Total Number : 5
5111 1/5
State: Historic
B24/4(right front body acceleration sensor): Zero point variation
5500 2/5
State: Historic
Critical vehicle level at front axle
5501 3/5
State: Historic
Critical vehicle level at rear axle
5503 4/5
State: Historic
Recovery time during filling of central reservoir is too long
5508 5/5
State: Current <===================== ONLY ONE CURRENT CODE
The pressure line system leaks
BENZ_EN_TEST_00003>E(211)>From 06-2005 to 05-2006>T-Model>Gasoline>211.256 - E 350>Manual>Suspension>View Data>Acceleration sensors:
Total Frames: 16 , Supported Items: 2
Frame 1/16:
030 B24/3(Left front body acceleration sensor) ----- 2509.80mV
031 B24/4(Right front body acceleration sensor) ----- 2509.80mV
Frame 2/16:
030 B24/3(Left front body acceleration sensor) ----- 2529.41mV
Frame 14/16:
Frame 15/16:
Frame 16/16:
>Suspension>View Data>Level Sensors:
Total Frames: 3 , Supported Items: 6
Frame 1/3:
040 Signal 1 of component B22/8(Left front level sensor) ----- 2.37V
041 Signal 2 of component B22/8(Left front level sensor) ----- 2.37V
043 Signal 1 of component B22/9(Right front level sensor) ----- 2.14V
044 Signal 2 of component B22/9(Right front level sensor) ----- 2.14V
046 Signal 1 of component B22/3(Rear axle level sensor) ----- 2.86V
047 Signal 2 of component B22/3(Rear axle level sensor) ----- 2.86V
>Suspension>View Data>Pressure sensor values:
Total Frames: 28 , Supported Item: 1
Frame 1/28:
049 B7(AIRmatic pressure sensor) ----- 6.45bar
>Suspension>View Data>Vehicle level:
Total Frames: 12 , Supported Items: 3
Frame 1/12:
042 Left front vehicle level ----- -14mm
045 Right front vehicle level ----- -11mm
048 Rear vehicle level ----- -4mm
Frame 12/12:
Suspension>View Data>Voltages:
Total Frames: 10 , Supported Items: 2
Frame 1/10:
091 Terminal 87 ----- ON
244 Terminal 30 ----- 13.90V
Suspension>View Data>Wake - Up process:
Total Frames: 50 , Supported Item: 1
Frame 1/50:
092 Wake-up process ----- OFF
Frame 50/50:
