Optimal tempreture for engine oil ?
Old Jul 21, 2022 | 09:24 AM
meki77's Avatar
S class
Hello I have s class v6 w221 ,the AMG dashboard displays that engine oil temperature is 99° the temperature outside is 34° and my AC is on ,just wanna make sure if the engine oil temperature is good or not ?
Old Jul 21, 2022 | 10:41 AM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
99C sounds about perfect to me.
Old Jul 21, 2022 | 01:05 PM
BOTUS's Avatar
S500
sounds warm - after what duration and type of driving ?
you should never give a car beans till the temps have stabilised across the entire engine block, gearbox, axel and wheel bearing and the engine oil is above 80C
the other day my tuned to death 1290 KTM at 25C ambient temps, still took more than 10 miles to reach 78C - then ragging to death you can get it to 85C
so if you're hitting 99C on an accurate gauge in the sump (rather than say the entrance into the oil cooler) inside 5 miles of gentle driving I'd say the oil is working too hard - but still inside its limits - decent modern oils can last for a bit at 300C with rubbish starting to play up at 220C
Old Jul 21, 2022 | 01:12 PM
kevm14's Avatar
In my experience the optimal oil temp is usually a bit warmer than the optimal coolant temp.
Old Jul 21, 2022 | 01:21 PM
BOTUS's Avatar
S500
yep, if just done 100 miles at 110mph I guess 99 to 120C for the oil would be perfectly normal
