loosing power
Old Nov 15, 2022 | 04:27 PM
lee ashton's Avatar
S350L
loosing power
OK the situation is my car will RADOMLY ONLY at low speed loose power, putting your foot on the gas pedal does nothing its doesnt move, I found when I pulled into my driveway, put the car in reverse and went to go back the car would rev but NOT move, 2-3 times its been in slow traffic and its stalled also
Old Nov 16, 2022 | 01:34 PM
BOTUS's Avatar
S500
modern cars are so complex, you can't really hope to resolve without an understanding of the very comprehensive fault code information the car collects and sends down the OBD2 diagnostic socket - this sits in the footwell on the steering wheel side
generic ODB2 diagnostic apps or ebay scanners are NOT worth the 10 to 50 dollar cost and on a Merc or BM highly likely will be of NO help at all. The ODB2 std mandates 6 out of a possible 16 emission related data points can be found from this socket - but Mercs diagnostics sends more like 1000 diagnostic codes here for lots of systems in the car
for example each of the ignition coils fail often as does the crank position sensor - you haven't even indicated if its a tractor or a real petrol engine?
Old Nov 17, 2022 | 01:36 AM
Senecat's Avatar
1983 Nissan Shltbox
What BOTUS said, but in two words;
Pull codes
Old Nov 18, 2022 | 05:03 AM
Lotus GT's Avatar
S 350 Petrol
I had something similar (not exactly the same) and it turned out to be both rear wheel speed sensor reluctor rings on the outer CV joints. They had completely disintegrated. Replaced both and have had no trouble since.
