07 S550 4Matic stuck in park
2007 S550 4Matic
I had to replace my lift compressor recently. I didn't drive the car while I waited for the part to come in. When I started the car back up I have Park Brake Inop, Cruise Control Inop, ABS and ESP Inop and Presafe Inop and my car wont move. I ran scan on the car and had speed sensor code for the front. I replaced both of them and I still have the same Issue before I replaced them. Any help would be much appreciated.
did you get any water in the F SAM box under the bonnet -or left something disconnected ?
if none of that might as well try - fully charge the battery - and if not disconnected doing that - then - in the boot lift the wheel cover and look for a red painted 13mm headed bolt on the side of the spare wheel well with a long flat earth cable - undo the bolt and leave cable away from bodywork (after unlocking the car or the alarm will sound) and leave off for 20 mins - reconnected and see where you are after BOTH these points - (reset windows and sunroof anti-trap afterwards)
