Removing upper/lower coolant hoses
My plan was to change both upper and lower hoses but I have not tried to remove the top/bottom metal inserts from where they are in and it seems like they are fused in. Now I am sure these are the orginal hoses and being that the car has 183k miles there is no doubt that there is dirt jammed in there make it impossible to remove them but I don’t know what else to use or do. I have added a picture.. the purple sure is the part that is stuck inside the radiator.
While I was doing this job, I noticed a curious and odd thing. On the hose connection referenced above (lower pipe into engine block, I noticed I was missing a chunk of the aluminum (or steel) pipe coming out of the engine block, broken off at the edge. It seems the connection is stil able to hold without leaks, but what on earth could have caused this? It is so buried in there behind the belts that it is hard to imagine I or anyone else could have created enough force to damage it. Could it just have been metal fatigue that finally broke off after 15 years or use? What I'm wondering is where the chunk is, and if it is floating around my cooling system, somewhere.
For your earlier question on installing new hoses, I recently replaced my radiator and when installing the hoses, I installed the metal clips on the hose first and then pressed the hose into the opening until I heard two clicks. To be sure the hose was installed properly, I gave the hose a slight pull to make sure it was seated and then started the engine and let it idle for a few minutes to make sure it was not leaking.
when its out baking soda and a tooth brush
https://allthingsaluminum.com/cleani...num-corrosion/
