2008 S550 washer pump connection?
Was changing my driver side headlight and noticed fluid started pouring out. What is this little thing that broke off the washer pump? Part number? I need to replace both pump and this little thing.
thanks
That hose runs from the pump to the hood and then to the sprayers. It has a heater wire inside it so you can't repair it with replacement sections or barbs. It's also not available anymore as a replacement. I put it somewhat into the right position on a new pump and then loaded it up with 2-part epoxy. I'm not even sure mine works anymore. I have a black car so I don't want to use it. Water spots suck.
https://www.ebay.com/itm/12501812330...mis&media=COPY
