Battery Drain from Door Module
I suspect this module has failed. I plan to pull the door apart and then find a replacement module of the same part number. My question is would an exact replacement module be plug and play or would I need to have it activated by the dealer xentry system?
Thanks in advance. Without all the great info I've absorbed from this forum I would been in the poorhouse years ago from paying others to diagnose and fix my cars.
there were software updates on early car's to the door modules - but likely you had it as the usual issue is the windows wont work due to hitting a thermal cut out that doesn't auto reset.. the funny semicircular trim panel you see with the door open (normally hidden by the end of the dash) just pops off with your hand and you should see the door module and its wiring
in general most Mercedes (and likely other cars) that use canbus fun, seem to get more voltage hungry with age... the idea with canbus is some weird beard networking and computers that do magic when they are behaving. If the car's voltage is lower than normal the logic around the network looses the plot and things forget to turn off - what causes what, in which order is the harder bit to find... are you aware at 2007 you might have a 35 amp hour battery up front and a monster 95 amp hour one hiding in the boot behind the rear seats ? if you have one in the boot, if no one ever touched it, it will be short of 200ml of water in each cell and almost not working...
if you get there to find its the original - I would recco a top up and recheck in 24hrs time then charge for 6 months - they are better made than replacement batteries and might (if given some TLC) in 8 months time, behave better than a brand new replacement
