water temperature warning light
Old Feb 9, 2023 | 02:15 AM
bwdream1974's Avatar
w221 s550
hello
This is a 2007 w221 s550 gasoline vehicle.
The following warning lights come on from time to time
No sensor error in diagnosis
Responds well to cooling fan output %
I replaced the thermostat
No abnormal coolant level
If anyone has experience or knows the cause, I'd love to share
Old Feb 9, 2023 | 03:47 AM
Shadly1's Avatar
2007 S550
Maybe corrosion in the coolant temperature sensor connector. If you dig deep enough to look at it, you might as well replace it. It's only $20.
What's that other dash light? The one above your MPH. Is that Distronic? I don't have it so I've never seen the indicator.
Old Feb 9, 2023 | 01:27 PM
BOTUS's Avatar
S500
its a graphic - not a light - he has a beep enabled, that detects if you aren't paying attention - its an additional feature with Distronic Plus - linked to BAS Plus (brake assist) - in today's world it like "city safety" but Merc forgot to put the brakes on - but if you instigate it brings a lively response to slowing down
