M278 4-Matic Crank Pulley Removal?
Old May 10, 2023 | 11:48 AM
efglover's Avatar
2012 Mercedes S550
Question M278 4-Matic Crank Pulley Removal?
I've been told not to use an impact wrench on the crank pulley for this engine so I purchased the flywheel locking tool but can't figure out where to use it from the WIS procedure.
Do I remove the starter on the left side or is there access to the flywheel on the right side? The procedure seems to indicate there is a crankcase cover on the right side but I can't spot it from underneath the car.
Any help will be appreciated.
Thanks!
