2007 S550 Starter battery - where is it?
My car has two of them, one large behind the rear seat and one small in the engine compartment. Both look new-ish (I bought car used). Few weeks ago I noticed that when starting up the starter mottor appears to "struggle" for one or two engine rotations, then it rotates normally and engine starts. When to a car battery shop, they tested both batteires (loading with 50% Amps rating) and concluded that both are good. The technician insists that the large one in trunk powers the starter, but most other sources (internet based mostly) vote for a small one near the engine.
Several months ago I left my headlights overnight and drained (one or the other?) battery. I managed to start a car by adding external battery to the one in trunk and jump starting.
So, few questions:
1. Which one is starter battery?
2. Can a test miss the failing battery?
3. If the battery is OK, why it appears that there is no strength when cranking the car. (warm or cold).
Thanks a lot
early cars get a battery under the bonnet that would suit a 1.6 litre 4cyl car with few toys - its sits the opposite side to the brake fluid reservoir above the heater blower motor
these cars gets a massive 25kg hidden consumer toy battery in the boot (behind the rear seat, accessed from the back of the boot)
if instead under the bonnet you have no space around a very chunky battery, that's half hidden as its so crammed in - you won't get the big battery in the boot
my original front battery still works - but I swapped it out a year ago after 15 years for good measure
the massive joke in the back can't cope unless the car does 50 miles of driving every week - yes it will do 2 1/2 weeks just sitting there but it will deplete to 50% of what it should have and be at the threshold of throwing low volt teddies and if you never look at full diagnostics 3 1/2 weeks on the car will still pretend its happy - it just won't have been
other merc's throw user messages it hit low volts - and starts with kit disabled (like non essential stuff - AKA screen demist fan and windscreen washers pumps !!! ), they come back to life when 2 to 5 miles have topped it up a bit - the w221 tends not to bother...
the harder it works the faster they age - so regular use and topping them up helps - NEVER believe the lies about sealed for life batteries - its only ever meant please don't top it up we sell more !
the rear is an AGM one designed for abuse - and can be topped up and charged on the bench and the original will likely give as good a service as any premium replacement that's past 18 month old - they have learnt to make them less well and also add less moisture on modern batteries and thus they start to age heavily from 20 months - where the originals would always do 9 years min
