M273 unstable idling performance
stuck in the low rev position you miss a lot of top end grunt - misfires could be coil sticks giving up or the inlet manifold doing what mercedes designed it to do
even if happy to accept performance and economy reduction - the catastrophic injection of rubbish into the combustion chamber is not a good idea....
used to be big bits of brass on BMW tractors (swirl flaps) - even when they moved to plastic - it still destroys the engine when ingested
I had also replaced the sealing ring due to the metal wire clamp attached to the maf fitting loose and sloppy over the top of the air box, after the new sealing ring it clamped on to it tight and could feel it snap on into place.
for USA market once upon a time there was a free manifold as the early ones were faulty.... don't believe any in europe had one
that said - unless inside bits already been ingested / failing I doubt this will cause a misfire
