Creak when backing up
08 s550 4 matic, when backing up and turning the wheel to exit the drive way I get a creak from driver side front area.
I cant know for sure if its the sway bar link since it doesn't make noise when going over bumps going straight. I cant only replicate it when backing up and turning the wheels while going over uneven surface.
Struts are new, forward Control arms new. No play in wheel.
Sway bar and its bushings?
Basically its exiting my drive way. So if I exit straight backing up, no noise. If I turn the wheel all the way or half, the driver side wheel exits out the driveway, while the angle of decend changes, the noise happens.
So I would think that its the pressure changes related to sway bar. But if the link was bad, wouldn't it make noise all the time? I will disconnect driver side sway bar link tomorrow and see if anything changes.
Noise is like a CLICK CLICK, type. Like up down.
Also noise started happening a bit while braking going over bumps. Hard to duplicate.
There is a condition where your sway bar bushings will shrink and slip in the mounts. You would notice that going over speed bumps though.
In theory, bad ball joint, sway bar link or anything loose would also be hear many times over going forward .
It never ends.
Im suspecting the lower back arm perhaps since this noise is mostly when turning going back. Its been there for months but its slowly getting a bit worse.
Only thing to do is wait for it to get worse. No shop I trust enough to trouble shoot this without throwing parts at it.
That visit cost me $1800 or so and they said nothing else is loose up front especially driver side. I did tell them about this specific creaking problem but they said all was tight and forward control arm should do it.
Bigger issue is I have 3-4 shops that do german cars and a dealer within 5 mile radius and none of them can be trusted. They all want to sell you parts you dont need and rip you off. I dont mind spending on the car but I hate being ripped off.
Example of their rip off. Last visit, guy says they did alignment after arm and axle change. I leave the and steering wheel is off by 20degrees at least.
Another shop. My 99 SL 500. I go in to have trans leak fixed, so I tell them to change filter and seal. They call back say my fan clutch is bad. I say ok, use MB part, $300-400 they say and I agree. I get the car back and it sounds like a UPS truck, fan clutch super stiff. Long story short, they used a BEHR part, not SACHS. Go back again, they apologize, install another BEHR part.
Finally I order SACHS part, have it installed locally, go back to german shop and demand a refund, which I got.
I miss having a newer car where the dealer covers all repairs. My previous car was a 08 Lexus LS460 with Lexus warranty I bought, 7 years ago. Anytime, no questions asked + loaner. That $3000 warranty covered about 10k worth of repairs in one year, 8 control arms, brake actuator, new headlight.
I wanted a w222 after this but I think it better come with a MB warranty or Lexus it is again. I love driving and taking long drives. I cant trust this car.
Your noise can be from the rearward lower control arm. It is the one carrying the weight of the car. The ball joint could be dry in a spot where it moves to when you turn the wheels and makes the sound only then. You say it does not do it if going forward but when do you turn wheels that much going forward?
I had this problem, and it was first on passenger side but it sounded like driver side inside the car.
Check the rubber protective boots on these rearward control arms. If they are broken you have found the source for the noise.
Mechanics saying no loose parts but to check wear/looseness of the ball joints in these cars you have to take the upper control arm (the wish bone) loose first and allow the wheel hub to turn in position where the forces in the joints go away. Without doing this it is not possible to shake the wheel with hand force for inspecting ball joints looseness.
on the 221 and many cheap german cars - because they can't be bothered to use wishbones top and bottom (which are a better way to build suspension systems - but cost more), we end up with budget stuff you get on base shopping cars...
the cornering loads from the front road wheels are transferred to the car, via the black painted steel TRACK CONTROL ARMS - (spring control arm !!!), and wow - surprisingly these also maintain the width between the wheels just like a train track
the braking forces trying to push the front wheels backward are controlled by aluminum CASTOR CONTROLS ARMS - (strut rod !!!) ...if you look at old ford's of yesterday year they rolled this part along with the front anti-roll bar to save money
together these two arms form a budget lower wishbone - with less control and less accuracy - and more or less allow the steering axis to remain about where we need it
you seriously think making the lower control arms with two arms AND ball joints is cheaper (lower cost) than a one-piece wishbone? Really?
It is way more expensive to make the 2-piece control arm system that MB use. Probably close to twice the cost. But perhaps they produce a feature a simple wishbone cannot?
And what comes to parts names: “Forward Lower Control Arm” and “Rearward Lower Control Arm” has been widely used in this forum. The first time I see “Castor” control arm or “Track” control arm.
The noise started happening while braking and going forward from time to time as well.
checking a BMW parts catalogue for good measure - again fitted with budget junk suspension the TRACK CONTROL ARMS (are called Wishbones !!! ) and CASTOR CONTROLS ARMS are called (Radius Arms !!! )
according to google A track control arm is the hinged suspension link that connects the chassis and the suspension that carries the wheel.
At this point, a good inspection would be a good plan but not a necessity. You have no reason to "parts cannon" your car.
still doing some home workFord Escort Mk1 front suspension kit
if you ever thought S class suspension was costly https://www.gartrac.com/products/esc...suspension-kit Forest / Gravel specification (pictured) consists of the following parts for $7400:
- 1 x Forest / Gravel Heavy Duty Steering Arm Kit
- 1 x Steering Rack (Select either LH or RH)
- 1 x Set of Engine Mounts and Fixing Bolts (Select either BDA LHD, BDA RHD or Pinto)
- 2 x Complete Gartrac Forest / Gravel Struts
- 2 x Bilstein 300/70 Long Inserts
- 2 x 11'' x 190LB (RYY) 5.25" O.D. Front Springs
- 2 x Top Rubber Rose Jointed Mounts
- 2 x Top Spring Caps 4"
- 2 x Lower Spring Seat 4"
- 2 x Alloy Lock Rings
- 2 x Strut Gaitors
- 2 x Standard TCA's (for Escort Mk1 FIA historic spec car)
- 1 x Gartrac Group 4 Large Bearing Front Hub Kit + Large Grease Caps, Spindle Washers and Hub Nuts
- 1 x Gartrac Heavy Duty Crossmember
- 2 x Metric Track Rod Ends
- 1 x Gartrac Twin Cam Anti-Roll Bar Kit (for Escort Mk1 FIA historic spec car)
- 2 x AP CP2361 Front Brake Calipers
- 2 x AP Vented Front Brake Discs
- 2 x Mounting Front Mounting Bells with Bolts
- 1 x Brake Pad Set
its a bit like language - if we can move to a standard its just easier more people take less time to understand and communicate clearly - that list with bold stuff conforms to the set up I said Ford use no Castor (as in castor on the chairs in your sitting room (or shopping trolley) as its control of this key angle that gives steering the self centering effect making the car stable....
Interesting these guys use TCA for Track control arms - yet ARB is a recent new world name for the Anti-roll bar (and these guys don't use it ). I was also thinking after seeing Vice Grip Garage and Derek struggling to get his head around the words Anti-clockwise (opposed to or against ), whereas he wanted counter-clockwise (1, The depressed part of the face of a coin, modal, or printing-type that gives relief and contrast to the raised part of the design. 2) One who counts or reckons; a computer; an auditor. 3) An apparatus for keeping count of revolutions or other movements.)
Now the noise migrated. Now I can simulate it by braking hard and letting off the brakes. Only hard braking. Brakes on off, i get a click sound. Also turning left full turn and brakes Ill get the sound.
Forward control arms new. Struts are 2 years old. He says ball joints are all fine. Sway bar links fine, sway bar bushings shot. So I would need a whole sway bar, fine. He said let it get worse so we can pin point it. This is the second shop telling me this.
Thoughts my dear friends?
