S600 list of ABC high pressure hoses - part numbers?
2014 E350 Wagon, 2007 S600, 2009 SL550 with ABC removed, 2011 S400 with Hybrid removed
Hello experts, has anyone figured out a list of part numbers for all of the S600 ABC high pressure hoses? (Hoses going from the pump to accumulators/valve block/struts)?
Why? They are not a common failure. I had 140,000 on my 221 S-65 and never had a hydraulic hose fail. Nitrogen bomb on the pump died twice.... but nothing else. You can have individual hoses remade with new hose; reusing the ends. They will last if needed.
2008 CL550, 2022 EQB300, 2022 EQS580
George993 (08-29-2023)
Hi, 2001 S600 W220 here. I am close to getting the old one out but I am stuck. On mine, I have a metal fluid accumulator (cylinder 4" long by 2" diameter) attached to the abc pump. It is on the side top of the abc pump and a metal tube goes to a bayonnet fitting that is attached to the pump. I have the 2 front E12 nuts off of the accumulator bracket. I have the fitting disconnected from the ABC pump. However, the metal tubing continues down towards the steering rack I think. Can you educate me on how to get that assembly disconnected, please? Do I have to lift the car and uncrews the tube from the top of the steering rack from underneath the car, please? Regards, Bo
Check out this link...should get you started...https://nemigaparts.com/cat_spares/e...71/65v/32/290/
nath_h (08-30-2023)
As first generation of ABC used on W220 is different from the second generation of W221 I don't think that the members here will be of much help (unless they have owned W220 before).
vettebk (08-31-2023)
